For an approximately 3500 sq foot rectangular 1 story traditional wood constructed house (50'wide x 70' long), I would want wifi coverage from front to end to allow wifi Ring cameras to work on both front and back ends. I plan on adding additional Ring cameras soon as there are significant homeless walking the streets and one recently came into the gated yard. The cable input and modem along with an old Ubiquiti Dream Machine (which I believe is wifi 5) are located in the back. So far, the front and back Ring cameras seem to work OK. However, my sister who is in the front finds the wifi strength to be lacking. She also needs a switch in her room to allow multiple devices to connect to the network. In the past, I have used the Netgear type Orbit mesh system which had multiple RJ45 inputs but am used to the Ubiquiti system so I can manage the devices remotely as I don't live with her.
I want to switch to the newer Ubiquiti Dream Router which uses wifi 6 technology, still placing it in the back of the house. To increase her signal to her room, I was wanting to use either the Extender or U6 Mesh/Mesh Pro but do not understand the differences between the 2 types of devices. Can someone explain what type would be more appropriate? Also is there a Ubiquiti product that would allow a switch (placed in the front of the house) to be plugged into the network without actually having to run cable to the front of the house such as the above mentioned Netgear type Orbit mesh device?
