My dad brought his Suburban for an emissions check and a free brake check, and when they had it lifted up they did a complimentary inspection. They noticed the u-joint was coming apart and my dad had mentioned a rubbing noise at certain speeds, and they said that the u-joint was a possible culprit. They also said it could possible break away if it wasn't fixed soon. They quoted him for $155 to replace it (this is an oil change shop that has a small garage on the side).
Is this is an easy job to do? It seems to be held on by c clips, but I don't don't what is entirely involved with dropping the drive shaft.
This is a pic of the damaged end of the u joint. The opposite side of the joint (but still on the same "fork" for lack of a better term) is also cracked looking.
