- Joined
- Jan 14, 2023
- Messages
- 37
What are some of the best Type F Transmission fluids out there?.
And how good is Warren Oil type F transmission fluid??
I'm confused by that Hot shot's product, it claims to be Allison C4, and it claims to have their friction reducer additive in it, which seems odd for a product that is recommend for use in Type F applications.
ATI Super F Synthetic Type F Automatic Transmission Fluid
www.atiracing.com
Hot Shot Heavy Duty Transmission Fluid | Ford Type F
Reduce extreme heat, noise & vibration, improve oxidation stability, and protect against wear with Hot Shot's heavy duty transmission fluid.www.hotshotsecret.com
Semi-Synthetic Racing Automatic Transmission Fluid Type F
Lucas Semi-Synthetic Type F Automatic Transmission Fluid is blended from premium base oils combined with a high-quality additive package that includes anti-wear, anti-oxidants and corrosion inhibitors and holds-up under the heat and stress of racing applications. Lucas Semi-Synthetic Type F...lucasoil.com
NO! Type-F fluid is ATF without friction-modification chemistry. If you're using it in a performance application then pick something like Red Line.So are Dexron fluids compatible?
Friction modification is part of the additive package. You can't separate the friction modifiers from the rest of the package. Type F fluids have specific additive package that provides wear protection, detergency, and a certain amount of lubricity. But the package lacks dynamic friction modification.I have heard in the past type f doesn't have friction modifiers like most atf fluids do..
How are we supposed to know? I already offered a high performance option in the second post of this thread. That's what a lot of people use at the drag strip. But hey, it's your vehicle, so you should save a few bucks where it counts.But if I was going to take it to the drag strip once a year would the Warren Type F be okay??
