First, how many of you use LC in your gear lube be it a manual tranny or an axle? I did a search earlier and found very little info on this other than it was OK, so I put about 1.5oz. in the 8.5" 10 bolt under my car today. I plan to change the gears and maybe posi in a month or so, so I wanted to clean things out. Think that is enough or should I add a little more?
Second Walmart has the Penzoil lower unit synthetic 75w-90 API GL-5 on clearance for $4 a quart. I use this in my little outboards, sure it is overkill as they put no stress on the gears but a quart will flush them a good 3+ times so it is cheap to use at the normal $6-7 price. The lable specifically note PAOs and esters as the base stock so sounds like no funny buissiness as far as truely synthetic or not.
Now here is the really stupid question laugh at me if you must, but would this be suitable for use as regular gear lube in automotive axles and such?
Both of my cars have Auburn posis so synthetic is sort of a nono anyway and I have another lube in mind for them so this question is really just curiosity.
