wwillson Staff member Joined Aug 20, 2003 Messages 7,988 Location Colorado Aug 31, 2024 #21 Jetronic said: And it's not like you are running a terrible amount of power on the interstate either. Are you even boosting? Click to expand... My 3.0L Duramax averages about 10 psi boost and EGTs of 950°F cruising down the interstate at 75MPH with no wind.
J Jetronic Joined Feb 27, 2009 Messages 11,593 Location down in the park Aug 31, 2024 #22 wwillson said: My 3.0L Duramax averages about 10 psi boost and EGTs of 950°F cruising down the interstate at 75MPH with no wind. Click to expand... Diesels do that, but often it's done to lean out the mixture more. Any idea what the AFR is then? I'm guessing 25:1 or leaner? My old diesel ran with boost everywhere aswell, except when performing a regen, than it ran 0 boost just cruising
S SHOZ Joined Jun 28, 2003 Messages 9,423 Location Illinois Aug 31, 2024 #23 Most modern turbos have passive cooling after the engine is off as coolant still convectively flows as it is cooling off/heat rising.
J Jetronic Joined Feb 27, 2009 Messages 11,593 Location down in the park Aug 31, 2024 #24 SHOZ said: Most modern turbos have passive cooling after the engine is off as coolant still convectively flows as it is cooling off/heat rising. Click to expand... except a minority of engines have coolant flowing through them at all, at least here. My new car doesn't
wwillson Staff member Joined Aug 20, 2003 Messages 7,988 Location Colorado Aug 31, 2024 #25 Jetronic said: Any idea what the AFR is then? I'm guessing 25:1 or leaner? Click to expand... I will check.
