My '01 Grand Marquis is tuned, part of which involved increasing transmission line pressure. I've been told the line pressure is the same across the board, except it has been increased from 33 PSI to 100 PSI at WOT. For anyone in the know, this is what the tuner's sent me:
Code:
Trans Tv Pressure 12
SGA2 - 1
5.000 0.000 12.000 23.000 23.000 25.000 26.000 28.000 100.000 100.000
-20.000 -7.000 12.000 23.000 23.000 25.000 26.000 28.000 100.000 100.000
SGA2 - 2
--- --- --- --- --- --- --- --- 33.000 33.000
Trans Tv Pressure 23
SGA2 - 1
-22.000 -22.000 -22.000 -15.000 0.000 6.000 8.000 15.000 100.000 100.000
-22.000 -22.000 -22.000 0.000 6.000 6.000 8.000 15.000 100.000 100.000
-22.000 -22.000 -5.000 0.000 6.000 6.000 8.000 15.000 100.000 100.000
-22.000 -8.000 -5.000 0.000 6.000 6.000 8.000 15.000 100.000 100.000
0.000 -8.000 -5.000 0.000 6.000 6.000 8.000 15.000 100.000 100.000
SGA2 - 2
--- --- --- --- --- --- --- --- 22.000 22.000
Trans Tv Pressure 12 is shift pressure from first to second, Trans Tv Pressure 23 is shift pressure from second to third. The first batch of numbers is the tune, the second batch underneath with the "---" is stock. I've been told "---" represents no change. I'm not sure what the "-" represents, because negative pressure would be a vacuum if you know what I mean. SGA2 is my PCM code.
To be honest, my pressure regulator is buzzing as I drive, so I am pretty sure some changes must have been made to line pressure other than WOT.
I use Motorcraft or Kendall branded Mercon V and always drain the torque converter so I get at least 14 quarts or so of fluid at each ATF change (25,000 miles). I use a Motorcraft FT-105 filter and also reset the PCM after I change the ATF.
If I reset the PCM, the car is as smooth as butter. As soon as it relearns its cycle, the car drives like it's on a leash. I find this very strange, because I was under the impression that the adaptive learning function would be disabled. For example sake, it's like a manual transmission that's stuck in gear and the RPMs won't go down when you release the gas. I took it up to 40 MPH and touched the brakes just enough to illuminate the brake lights, and the RPMs does not drop...stays at roughly 1,300 rpm. So I replaced the TCC solenoid to no avail. It still does the same thing.
Here's where it gets worse. Sometimes as I'm coming to a stop, I feel a thump and the RPMs go down - usually to 4xx RPM and back up to 600 RPM (idle speed raised to 600 in gear and 800 in park/neutral). If it goes lower to 1XX RPM, the engine stalls.
I have a feeling this is the tune, so I've contacted Lonnie at Blue Oval Chips, considering his mastery with mail tunes. But I'm still not ruling out the possibility of a mechanical issue. Any ideas?
Code:
SGA2 - 1
SGA2 - 2
SGA2 - 1
SGA2 - 2
