I own a 97 Chevy Silverado with stock fuel injection, yet with 383 stroker; and on cold starts the engine either dies after a couple seconds (just as oil pressure rises), or will try to turn over but idle is VERY rough for about 15 seconds....we're talkin ka-chug ka-chug. IAC valve takes over after awhile and then things go back to "normal." I'm not sure if its a vacuum leak, fuel pressure regulator, spark problem, MAP sensor, or injector issue. Here's what I do know:
Sprayed starting fluid all around base of intake manifold to see if idle would rise...it did not.
Checked other hoses etc. for possible vacuum leaks. Found none.
Checked plugs, and found out that one banks (passenger side) plugs were in bad shape. Lean condition or vacuum leak symptoms. Yet other banks plugs were perfect.(bad 02 sensor?)
Checked MAP on scanner and I'm getting 14.8 at idle (LT4 Hotcam)
No trouble codes
This only occurs on cold starts. On warm starts (up to 1.5 hours between starts) Engine will start fine.
No trouble codes
