So I'm looking for some guidance in solving this problem as it is a obd2 issue and should be some general info on this even though my swap is specific.
So i finally got on it and went wot, short shifted around 5k rpm. Went to accell in 2nd gear and car went limp, little to no power. Felt like it was down 4 cylinders. Limped it off the highway to find i had a new error code.
po200 injector circuit malfunction
Pulled the battery cable for 5 minute and restarted, everything is back to normal. What would cause it to throw a code.
Setup:
2002 ls1/t6 pullout with pcm
custom integrated harness into bmw e36 chassis
camshaft setup only, everything else is stock
TIA
Setup:
TIA
