Do you guys do anything to lube the trimmer head on your lawn trimmers? I noticed the other day that my 8-year-old trimmer head sounds like a dry bearing when it's spinning fast. It's not whining or screaming, it just sounds dry. It also gets pretty warm during use. I've poured some Redline gear oil down the shaft a couple of times, and watched it pour out the seams, but was unable to split the case to actually stuff some grease into it, which I think it may need. You guys do anything for these, or just replace them when they fail?
