Traveler 15W40 CJ-4
TN
Hello, I just picked up a 1997 F250 with the 7.3 diesel. My local tractor supply has the 2.5 gallon jugs of Traveler all fleet 15W40 for $21.99! I figured $2/quart for HDEO is pretty good. What is the opinion on this oil here? I have seen some CI-4 used oil analysis, but what about the CJ-4 formulation? I'm probably sweating over nothing here, but if it's gtg, I'd be happy to use it over the $3/qt Rotella. Thanks!
Once we head back into cooler weather 10w30 works just fine in a 7.3 and will reduce the cold start romp.
Ok guys. I went to Walmart today to get my FL-1995 filter, and I saw Valvoline "High mileage" Maxlife HDEO, 15W40, semi-syn. I went to see how much it rang up as, it was $11.67/gallon! I just picked up four gallons of it and put it in the truck. I'll try to get a used oil analysis on it when I change it out
I used to have a 2002 F350 4x4 with the good old 7.3 made by International, awsome motor and very dependable. I used mostly the MotorCraft 15w40 in the 5 quart jugs sold at Walmart along with the Motor Craft FL1995 oil filter. As long as you use a decent diesel oil and good oil filter like the Motor Craft, you will be fine. I now have a 2011 Ram 3500 4x4 and use the Rotella T-6 with the Cummins Oil Filter.
Clean oil is the best oil,
That aside, tsc has travelers on sale right now 39$ per 5 gal pale. I just picked up 40 gallons. I use it in everything without issue.
I like it. Stout add-pak and seems fine in some of the field tractors
Good snag!!
Can't beat the $$$ and the Valvoline is going to work well.
