http://www.trasko-usa.com/swtesting.htm
TESTING PERFORMED BY:
S O U T H W E S T R E S E A R C H I N S T I T U T E
San Antonio, Texas / Detroit, Michigan / Washington, D.C.
ISO9002- O.E.M. Mechanical Integrity Tests
Click Here to see Spot Test comparisons.
Resistance to Flow (per hs806)
SAE J806 (Single Pass)
SAE J1858 (Multi Pass)
Click above charts for larger image.
OEM testing procedure measures mechanical characteristics of filters. Shunt type stock filters available in the market provide excellent mechanical efficiencies as high as 94% and capacities up to 21 grams. But, none opt to focus on adsorptive qualities or chemical efficiency. Internal combustion engines produce contaminants other than metal shavings that are less than a micron in size. Purifying circulating oil chemically by suppressing oxidation, removing water content/moisture and maintaining viscosity by extending thermal breakdown point (cooling fins reducing oil temperature by 20%) are the added features to the TRASKO. Spot test and Field tests represent the difference for these added features. TRASKO IS A REFINING UNIT UNDER THE HOOD.
TRASKO RELIEF VALVE (Per HS 806)
TRASKO RELIEF VALVE (PER HS 806) trastst2.jpg - 22.84 K
Click above chart for larger image.
