I cannot believe that there any SAE paper can prove that TES-295 "sucks". And I think that companies like Mobil, Shell, Amsoil, Schaeffers and others would disagree as well. The licensed and cloned products are often the top offering in their respective product lines. Feel free to quote the SAE paper document number; I'd be very interested to buy and read that document. At a bare minimum, provide the link to the thread post here on BITOG that makes that assertion, please. Further, which "guy" are you referring to? I'd like to have a conversation with him!
As for a TES-295 fluid being inferior to DEX VI, I'd have to question that as well.
We must understand that there are some applications where they are interchangeable, and some where they are not. So it depends upon the use. In some cases, DEX VI is going to be a much better choice because of it's thinner vis. In other app's, I'd take a TES-295 over the DEX VI every time. As with all lube topics, you cannot pick a clear winner because there are too many useage variables to say one is flat out "best" for every situation. It's no different than engine oils; there are "better" choices for given situations, but there is no "best" oil.
DEX VI is a great fluid; excellent vis retention and oxidation resistance. But isn't that also the battle cry of PAOs? Why would a TES-295 fluid be inferior to DEX VI?
Here's a little known fact. In the "new" GM Allison transmissions in the trucks, the DEX VI is standard fill. And those trucks have a "high idle" feature for cold temps where the engine is used against the transmission torque converter to warm up both in a quicker fassion. But GM discovered that the DEX VI does not react well to that operation in uber cold temps (well below zero F), and actually recommends TES-295 fluids for those extreme cold environments.
Also, in Allison testing, DEX VI was never certified for use past the "non-TES-295" OCI limits. That doesn't mean it's inferior, but it surely cannot prove that it's as good as TES-295 in severe duty use. The TES-295 fluids are certified for extended OCI even under severe use. And Allison has a very good, defined meaning of severe. They are talking about the type of use where low speeds and high torque loads are flashing the torque converter all day long. Use such as refuse trucks, shuttle busses, etc. Only TES-295 fluids are certified for extended OCIs in that regard, and DEX VI never was. Maybe DEX VI was never tested to that standard, so perhaps it could have passed muster, but as of this point, there is no proof that DEX VI is superior to TES-295. My point is that the absence of DEX VI as an approved TES-295 fluid may have been due to the fact that it was never tested, or it may have been tested and not passed. But we can be CERTAIN that it never approved for TES-295 certification. For all we know, it may have failed only because it has (on purpose) a vis that was too low for TES-295 certification. I don't know because I'm not privy to that testing protocol. All I know is that only the highest end products in each brand, costing the most money, pass that licensing standard. Even non-licensed products (ATD vs. ATF in Amsoil's line) cost more for the "cloned" fluid. Since Amsoil has no license to pay for, why would ATD cost more? It's only logical to believe that ATD has some base stock and additive package that is superior to even their ATF product. Bottom line: TES-295 standards are very demanding, and only the highest performing products pass the finish line.
I would say that DEX VI is a giant leap ahead of DEX IIIh fluids, but there is no reasonable proof I've seen that it's superior to TES-295 products.
Further, I'm not stating that only PAOs can be licensed; I'm just not aware of any non-PAO products that fill that spec. I put very little faith in marketing descriptions of fluids these days. Regardless, if Shell has a product that is TES-295 licensed, then it's a very stout fluid, no matter if it uses Jell-O as it's base stock. BTW - I don't see Shell having a licensed TES-295 product, so I don't know what product you're referring to, but it's not on this official Allison page:
http://www.allisontransmission.com/service/autoapp/172/viewpage.jsp?ThisPage=3.
Which is why I say marketing words mean little to me. "Suitable for use" is one thing, and an approved license is completely different. That is a whole othe topic; that of licenses versus marketing intent.
I'm not saying you're wrong, but I see no evidence that DEX VI is the "best" over TES-295 fluids, and knowledge of the testing standards and conditions suggest that logic direct us to other conclusions.
Some people and companies fear thinner fluids, and perhaps that's why Allison didn't like DEX VI. I don't fear thin fluids; I'm known for using OEM spec'd think fluids. But for some reason, Allison never licensed DEX VI to TES-285 standards. That's all we can know.
The only way to know FOR SURE is to use both fluids in the same exact situation, and then do used oil analysis and equipment tear-down analysis for performance validation. And Allison has already done that for me to a degree and level much deeper than my pocketbook could ever fund.
AS for TES-295 not passing (former) DEX IIIh spec's, that seems specious to me. Any moderate dino fluid could pass DEX III; only top end PAOs have been TES-295 licensed. Just what part of the spec would a TES-295 have failed in former DEX III licensing by GM? TES-295 fluids were designed for top tier performance in DEX III applications. Your comments seem counter intuitive to me. (This would be akin to suggesting that Mobil 1 engine oil is not approved for use in their Mobil Clean 5000 applications. To me, it just doesn't make sense). Now, what might be true is that companies marketing fluids in both TES-295 and (former) DEX III applications, never submitted their TES-295 products for DEX III license approval, but that does NOT mean they could not have passed the former spec. Again, look to Amsoil's offerings; anywhere you see ATF recommended for former DEX III app's, you could upgrade to ATD. But they do not recommend ATF for TES-295 applications. And both would be suitable for former DEX III applications!
Here's something else to know about DEX III, DEX VI and TES standards:
The fomer DEX III standard was primarily based upon moderate performance standards; it wasn't too demanding and it would allow for a broad range of base stocks. It was very similar to Ford's former Mercon spec, performance wise, and that's why you would see brands multi-market to both specs.
The DEX VI is a much more demanding performance standard, but it ALSO has a very specific chemistry package license requirment, so that a DEX VI product has to have that chemistry to pass the spec. There are EXCELLENT ATF products that don't pass this DEX VI license simply because they have a different vis and do not contain that particular chemistry package (that was initially only developed by one company for GM).
Allison's TES-295 is a VERY demanding performance standard, but it does not require any particular chemistry that I'm aware of. However, becaues the performance is so demanding, it's typically only successfully passed by products that have top end PAO stock (or perhaps group III, although I cannot prove/disprove this claim).
TES-389 is essentially an Allison standard that mimic'd the former DEX III performance specs, so that conventional oils could be used for lesser cost applications. It also addresses the whole "seal compatibility chemistry" issue for the Allison transmissions. There is a long list of conventional lubes that meet this standard:
https://fdlrd.swri.org/Allison/ApprovedFluidsList.aspx?Id=2
Anywhere you could use a TES-389 fluid, you could "upgrade" to a TES-295 fluid for longer intervals and higher performance.
Note that the fluid you referred to , Donax TX, is
NOT TES-295 licensed, but it
IS TES-389 licensed. Apparently it could pass the "lesser" standard, but not the higher standard at Allison!
So, it's true to say that a TES-295 could never attain a DEX VI license, but that's because it was never desgined or inteded to do so. TES-295 is a performance spec desgined for DEX III applications. DEX VI was desgined for thinner fluid applications, and is backwards compatible (only in some applications) to DEX III apps and it is very much a chemistry spec as well as a performance spec.
In equipment that was designed for former DEX III use, I would choose a TES-295 fluid every time over DEX VI if PERFORMANCE were the main deciding factor. There are, however, applications where the equipment was designed for thinner fluids and DEX VI would be more appropriate.
