I had a situation with the Ranger in my signature today that has me baffled.
Got in the truck today, drove 25 miles today, and parked it.
Came out, put key in it and it would not start. Tried everything to get it started and finally on a whim decided to hit the remote start. Ripped right off.
As I went about the rest of my agenda, it did the same thing 3 times out of 4 stops. Started right up with the remote.
Drove home and got my spare key, put it in the ignition and the truck started.
Ended up tearing the kick panel off the dash to get the transponder key hooked up to the remote. Put that key in the ignition and it started right up.
Took both the working keys, went to the local Ford dealer and had another one cut. Took it out to the truck, programmed it, and it worked fine. Took the problematic key, programmed it, and it appears to be working fine now. Guys at the dealer never heard of that happening.
Fortunately, I now have a backup for the backup so it will be much easier to deal with should this happen again. Any ideas why this would have occurred?
