I have a 2004 Mercury Sable with the ax4n transmission. It only has 130k miles. I just changed the fluid which is 8 out of 13 quarts, plus filter and pan cleaning. Fluid was gross but didn't seem too bad. The magnet wasn't that bad so I assume its been changed at some point.
I just bought it.
Anyways, ONLY when I'm on the gas, there's a faint supercharger type whine that starts at 30mph and goes until 45mph. When I let off the gas, the whine goes away within a second. If I hit the gas harder, the whine changes in pitch. Otherwise, it's the same 30-45mph.
Also, when the transmission warms up and the torque converter locks up, it shifts abruptly into OD and the transmission kind of shudders/jolta very quickly but not harshly. When cold (i never drive it stone cold) it shifts into 4th smoothly.
Fluid is at the right mark. My other ax4n has 237k miles and shifts like new. Not sure what's wrong with this one! Worried it's the torque converter going out, or just a bearing noise that does not mean upcoming implosion.
I just bought it.
