"Gear oil is primarily used in heavy machinery and large trucks. It is unknown if any engines were damaged by the bad oil, but it is likely that, given California's overall mild climate compared with the rest of the United States, no actual damage was done to any Californian's machinery, as any damage would likely occur only in extreme hot or cold temperatures."
At it's core, even the idiot writing the summary can't understand that "gear oil" does not belong in the "engine".
I wasn't there; I have no idea just how "bad" the bad gear oil was. So it didn't meet viscosity specs? How far was it off? Was it of by a few grade points (barely below a 75w?), or was it stupid low (like water?). Or, thick like molases? We don't know; we weren't there.
Also, I don't know of many "heavy machinery and large truck" operators that do their shopping for gear oil in Wally World. ST gear oil is used by us small source, low quantity consumers most of the time. It's not like you pick up ST in bulk 55 gallon drums and drive it over to the construction lot to put in your D-8 Cat ...
I'm glad that someone is checking the quality of ST fluids. That they didn't meet spec's isn't too suprising, but that can probably be said of any of the major brands. Occasionally, a quality control problem is bound to occur; not that's it's desirable, but it does happen to many good brands, just as it happened to ST. I can recall complaints against Wix and Purolator, but I consider them to be good brands. Wally's ST fluids fill a wide market with good overall performance.
So the question becomes: how bad and how widespread was the issue, and what damage resulted from the problem. The reality is that probably no one but Wally and Warren suffered.
If the OP is looking for a decent quality diff fluid to use with moderate OCIs, I would not hesitate to use ST fluids. Is it the "best" as far as extreme performance limits? No, it's not. But it doesn't cost and arm/leg either. It's well priced, performs adequately in most all applicaitons when used within OCI concerns, and has ease of availability.
Let's not let oil biggotry interfere with common sense, folks.
