AZjeff
$50 Site Donor 2023
I use an 05 GMC Sierra 1500/5.3 2wd xcab to tow a small 5th wheel. Recently moved up from a 3000 lb dry trailer to a 4500 lb dry trailer. With the smaller one the transmission could lock up in OD at 65 mph and I'd see temp around 160, going to 180 in moderate hills and tops at 205 on long pulls uphill. With this heavier trailer I'm seeing 180 on flat ground and the truck runs in 3rd gear mostly and recently on a long interstate uphill it reached 210 and stayed there until I reached the campsite after 10 miles of 25 mph uphill dirt road after exiting the interstate, probably 45 minutes @ 210. 69K on the truck, had a synthetic flush @ 50K. I have a Flex-a-lite cooler on the way that should help but is it enough? Is that kind of temp something to worry about or not? I installed a gauge so the temps are accurate.
