The motor guy
Thread starter
- Joined
- Nov 29, 2009
- Messages
- 10,258
Originally Posted By: chemman
Remember with aluminum, once it is exposed to air, an essentially invisible layer of aluminum oxide forms rather quickly. Aluminum oxide is not a very good electrical conductor. After you polish the aluminum and make your ground connection, you might want to spray some battery terminal sealant over the connection to slow down the inevitable process of aluminum turning into aluminum oxide.
Learn something new everyday. It looked clean to me, but I guess not clean enough. I'm used to galvanized trailers, not aluminum I beam.
