Tractor loader pins - Shell Gadus S2 V220 2
NC
I have a compact tractor with loader and backhoe. The grease I have been using for the pivot pins is Shell Gadus S2 V220 2.
Research for the best grease for pivot pins has me interested in Schaeffers 238. How do I tell what type of lithium is the Gadus S2 V220 is and if compatible with Schaeffers 238?
The fittings are most likely a purge fitting. Schaffers is Aluminum and Shell is lythium base so may be not ,so if youwant Schaffers youcan pump out the old grease from the pins. Call Scheffers for their recommendations .
Phone: 314.865.4100
Toll Free: 800.325.9962 Schaffers phone numbers.
Fax: 314.865.4107
I did go through the parts diagram for the loader and backhoe. No seals are present on the pins.
