19 Accord LX 1.5T, CVT transmission.
100k miles. Busted up Michigan roads
Slowly developed vibration and noise that isn't noticeable until above 30mph.
Becomes louder with with speed. Not super loud--but a very noticeable rhythmic droning.
Character does not change with acceleration, stopping, turning, etc. Just volume and of course, tempo.
Can feel it through the gas pedal/floor area, and a bit through the steering wheel.
Tires seem ok, low mileage CC2, RE-balanced several times to rule them out.
DT said rims look fine.
No play in wheel bearings.
Checked with stethoscope, dead silent except the shhhh sound likely from the pads.
All other suspension components appear in good shape, and are tight.
However, my specialty was drivability (with solenoid carbs, about a million miles of vacuum line, lean burn ignition, etc), so I admit heavy was never my bag.
The intermediate shaft bearing had clicking detectable with stethoscope, and I had a substantial amount of movement at the inner CV joint and/or the intermediate shaft bearing. Hard to tell which allowed the movement.
Driver's inner CV had just barely detectable movement, with a faint click.
Replaced the passenger axle and intermediate shaft with OEM parts, which improved the issue substantially.
However, there is still a noise/vibration...
I believe I fixed one of two issues.
There is a lot less midrange tone, but what remains is a lower frequency tone.
My best guess is the driver's CV axle is on the way out.
Silly question: is it possible for a wheel bearing to be bad, but not noisy?
The stethoscope has impressive amplification, so I doubt it. I definitely had the probe right on the bearing housings.
Though I doubt they are the issue, I'm also considering a 2nd opinion, just to be sure to rule out tires or rims.
Sometimes a different set of eyes can pick things up.
Forgot to mention that the wheels have been rotated several times, with no notable change in the noise/vibration.
Thoughts from the awesome BITOGers?
Bob
Bob
