Just changed my TP in the Motor Guard tonight. The consumption is up to about .8 quarts per 2000 mile filter change. That means it takes about $10.00 worth of Amsoil ACD per 2000 miles. I hate to go back to dino, but with technology closing the gap between conventional and synthetic, I may consider it. I took a sample right before the filter change and it's going to Blackstone tomorrow. This will be my first UOA with the TP bypass filter. 14,000 rural mail route miles since the last drain. The engine has 265,600 miles on it , which is at least 16,000 hours by my estimate, and the valve cover has never been off of it. I wonder what it looks like under there. Since changing out the factory fill, it's never had anything but Amsoil or Mobil 1 in it, although I let a couple of those OCIs go too long with the Mobil 1 early in it's life. I wonder if that's why the consumtion has gone up so much in the last 50,000 miles. I sure wish I had installed a bypass filter on it within the first few thousand miles. It might be making a difference right now. So what dino are you using with the Frantz or Motor Guard TP filters? Ralph says some oils turn dark with use and others don't. My Amosil turns dark. It would be much easier to see when the oil is getting dirty if the additives did not turn dark from heat. Your thoughts on this? Thanks.
