Built_Well
Okay MaximaGuy, I'll buy new gallons, just in case.
Hmm, I just noticed a bit of an inconsistency. The CD of Toyota's repair manual for the Camry seems to indicate the radiator's capacity is 6.6 quarts since the directions are
"(b) Add the engine coolant into the radiator until it overflows.
Capacity: 6.6 U.S. quarts"
But my 2006 Owner's Manual for the Camry says on Page 336 that the *total* capacity of the Cooling System is 6.6 quarts.
Oh well, I'll just assume that the radiator's fluid capacity is roughly 40 percent of the entire cooling system's capacity (radiator, engine, heater core, hoses, etc.).
So I'll assume on the first drain-and-fill of the radiator, 60 percent of the old coolant in the entire system will remain. Doing some quick calculations on a piece of paper, I see it will take 4 drain-and-fills to reach the point where only 13 percent (12.96) of the old coolant remains.
So:
After 1 d&f, 60 percent of old coolant remains.
After 2 d&fs, 36 percent of old coolant remains.
After 3 d&fs, 22 percent of old coolant remains (21.6 %).
After 4 d&fs, 13 percent of old coolant remains (12.96 %).
After 5 d&fs, 8 percent of old coolant remains (7.776 &).
Now for the rough calculations:
After 6 d&fs, very roughly 4 percent of the old coolant remains.
After 7 d&fs, very roughly 2.6 percent of old coolant remains.
After 8 d&fs, very roughly 1.6 percent of old coolant remains.
After 9 d&fs, very roughly 1 percent of old coolant remains.
Is there any problem running with 13 percent of the old coolant in your car after 4 d&fs? Or will I have to be a masochist and get it down to 1 percent and do 9 d&fs?
I don't intend to open the Engine Block's drain plug, or do a flush. I'm going to keep it simple and just do radiator drain-and-fills. Probably 4 d&fs this year, and another 4 d&fs next year. What do you all think? Reasonable strategy or not?
