WE have a Anderson hitch for our Fleetwood Terry 245 CK?. We towed it home from Michigan and have towed it across Kentucky a couple times. My truck is a Ram 1500 with the 5.7 Hemi and it has components from hitch rails to the frame of the truck. Our Anderson hitch is the earlier model made with steel but it still only weighs in at 40 lbs. I have had no problems with it. We get 11 mpg while towing with the transmission in tow mode. I am not complaining one bit. Ours has leaf springs on the rear of our truck and I added a helper spring to level it up. It is a lot easier to hook up since I can see what is happening with alignment in the rear view mirror. Pay close attention to your tire pressures on the truck and the trailer cause they heat up if not correct and cause trouble.
