Originally Posted By: userfriendly
I'll go along with light weight engine oils such as 0W12, could have a high VI.
How much would a pump operating in relief add to the sump oil temperature?
That's the rub, and where CATERHAM's lack of grasp of even the simplest of science is apparent.
Even an extreme 10gpm set up at full noise, with a relief at 80psi, and CATERHAM blend dropping it to 60psi, the heat reduction in the sump due to the pump relief is of the order of 100W. Compared to the whole numbers of KW being GENERATED in the bearings, it's trivial, but he hands onto it regardless.
And that's the rub...he doesn't understand that the temperature rise across the bearings is due to the viscous shearing within the bearings, not "carrying away the heat of combustion".
That's why he simply doesn't get that bulk temperature and oil pressure tell you absolutely nothing about the temperatures and conditions within the big end, and until he crosses that Rubicon, he'll never get that the universe isn't his linear simplistic model.
Here's my post from earlier...using bearing design formulae and tables for two extremes. As we've discussed in other threads, a 10W could be labelled a 10W16 under the current J300, so it's clearly relevent.
CATERHAM labels it obfuscation, but they are bearing design principals that haven't changed to meet his linear universe.
Originally Posted By: Shannow
https://bobistheoilguy.com/forums/ubbthreads.php/topics/1212972/Re:_OIL_"Cushion&#Post1212972
Shannow back in 2008 said:
Seeing as I'm having the day off, I worked through the example at the end of the spreadsheet that Gary and JAG posted, of the SAE 10 and 40 weight oils in the same.
Results were (note, too many significant figures for the printed graphs)
SAE 40 had 63% increase in film thickness over SAE10
SAE 40 had 61% increase in power requirement over SAE10
SAE 40 had 5F increase in Delta T (10F in outlet temp)
SAE 40 had 7.5% lower side flow (leakage and cooling)
SAE 40 had 113% more viscosity than SAE10 at working temp.
And having used the graphs in the spreadsheet, I'm Soooo glad that I studied in S.I....no wonder things run into Mars every now and then.
It is what it is...fact...
Look at this (it's racing, so it's relevant)
/http://www.eng.auburn.edu/~jacksr7/SAE2002013355.pdf
Has big end MOFT versus RPM and a range of viscsities.
The OP's engine is capable of 80% torque off idle, unlike the Astra engine that CATERHAM is familiar with.
at 2,000RPM, 80% load (torque), OP need way more MOFT, (and thus viscosity) than a torqueless Astra.
