Toshiba laptop display problem
USA
I have a Toshiba Satellite A105-xxxx that I've had for two years. I don't use it as much as I thought I would (surprise!) so it's not as though I've worn it out.
I booted it up this evening and found that only 60% of the display is there, i.e., there is a black space on the right 40% side of the screen. I hit "function and F5" simultaneously (per Toshiba's written instructions) and all that I got out of that was vertical "test pattern" lines like the TV sets of the 60s.
I tried to go into the control panel and "display" to work with the settings, but the laptop locks up each time I do that.
Is it my settings or did the screen take a dive? Fortunately, it's one of the very fews times I've purchased an extended warranty on anything.
Thanks in advance for the constructive advice.
Sounds like the video controller may have died. Especially if it's locking up.
If the LCD were in fact half-fried, the computer itself would not misbehave.
An easy way to check would be to hook it up to an external monitor.
What's a video controller cost (warranty covers that, right) and standby while I hook the laptop up to my Viewsonic.
If it's an onboard integrated video controller, it costs exactly the same as the motherboard. I'm glad you have the warranty.
Never mind on hooking the Toshiba to my Viewsonic. My HP and Viewsonic sync P/S2 to P/S2. If I'm stopping by MicroCenter for a P/S2 to USB connection, I might as well take the laptop in for a new video controller.
Thanks for the advice.
XS650:
Video controller equals video card, right? If so, I believe you are correct in that they are integrated on the A105-4104 Satellite Toshiba. Something about the mfr. saving space and $$.
XS650:
Yup, very dependant upon the manufacturer of the notebook and even then, deviations of different trim levels of a certain model can change this.
I had two Inspiron notebooks apart recently. Same model. But one was a "higher trim" version of the same model and had an ATI X1400 video card in it.
Same motherboard. BUT, on the lower-end model, the board had the DVI header for the LCD on the physical board and there was no socket soldered on for the PCI-Express connector. The spot to solder it on was there, it just wasn't.
On the other board, the socket for the on-board DVI connector wasn't soldered on, but the PCI-Express connector WAS. And it had a removable video card, manufactured by Foxcon, which was the ATI card.
So, two notebooks of the same model, but different trims and one had a replaceable video card the other didn't
