- Joined
- Oct 14, 2023
- Messages
- 142
This is old, and has likely been discussed on this site before, but still a very vivid and revealing video about torsional rigidity attributes of vehicles. Silverado is a class above Ford F in this specific case!
All things are a compromise.
The flex in the Ford frame may make for a difficult time to open the tailgate while in that bind, but then it also allows the Ford to keep it's suspension in contact with the ground for more thrust because of the frame articulation. As the Chevy has very little twist in the frame, and not much suspension articulation, it actually loses ground contact sooner and for longer duration.
I'm not saying one is better than another. I have owned both Ford and Chevy trucks and I have my preferences.
As a counter punch (so to speak) there's a good video of the new 10spd transmissions being reviewed by Randy's Transmission. They do a teardown of the GM "Allison" 10L vs the Ford 10R in the HD trucks. The Ford trans is much beefier in many aspects. You can search the video, but I cannot link it here due to some minor profanity in the video.
My point? There is no perfect truck. All things are a culmination of compromises. The "best truck" is the one that fits the individual's needs with the least detriments in his/her personal application. As many applications vary, so will the perception of what's "best".
See post #2 in this very save thread. Stiffer frame aids suspension, not the opposite
TL;DR: if "your" brand isn't the best [insert genital measuring category here] today, wait a few years and it will be, until it's not again.
Maybe same reason the big class 8 trucks have them?Some engineer should chime in here, but I think making a ladder frame stiffer, also leads to using stronger steel alloys which are also more brittle and can't take many extreme load cycles, which leads to more catastrophic frame failures?
I'd like to see a solid engineering explanation on why ladder frames are still used in light duty trucks at all? Must be still cheaper and potentially hard to convince the customer base?
I think the only real advantages of ladder frames is that they are cheap to make, (if you don't need extreme lightness or stiffness), relatively tough(if you let them flex), and can easily be made different lengths for different body, axle, and bed configurations.Maybe same reason the big class 8 trucks have them?
So what other frame style would be better? A truss style, with a roll cage? Or your thinking a unibody pickup truck?
A friend has a Tundra, I can see his camper shell move with the bed over bumps.Supreme!
Total articulation of the tires is a combo of both frame and suspension movement. My point is that a stiffer frame does have disadvantages. Now, maybe those disadvantages don't mean much in someone's application. But it may be in someone else's application.
A stiffer frame which restricts frame movement must be compensated by more suspension movement. That in turn can lead to more lateral sway with leaf-spring suspensions.
Also, that Ford chassis in the video is not current; the new SD is much different and stiffer.
Every pro has a corresponding con; that was my point.
