Exactly the right way to do it.Unless you work at a tire store tightening lug nuts day in and day out, what is the point? I can use an impact to set the lug nuts to an initial torque, then finish with a torque wrench.
Yes b’y. Foot lbs on the go.Do they come in normal units ? I used to call those Newfy meters !![]()
Stay where ya et … I’ll comes where ya to ! Fun people for sureYes b’y. Foot lbs on the go.![]()
Came across these 1/2 torque sticks allegedly for controlling the amount of torque applied to a bolt with an impact wrench. About $60 US equivalent. Does anyone use something like these?
It’s a Harbor Freight Earthquake XT compositeWhat kind of impact?
That’s a nice impact. Had no idea Proto made impacts. I may have to give them a look.That does not really matter if you are feathering the trigger, I rarely take mine off the max setting. Some are easier to feather than others, my Proto is easy the old IR231 not as easy but doable. I think it has to do with the trigger mechanism design.
This is the one I use most, the thing is incredibly balanced with the handle forward design.
https://www.protoindustrial.com/en/...s/J150WP_Proto®-1|2"-Drive-Air-Impact-Wrench/
