Toro (Homelite) string trimmer diaphragm needed
Eastern Massachusetts
I have a Toro 51936 string trimmer that is made by Homelite.
The carb is an assembly 3074501 and around $100.
All the carb needs is a diaphragm.
If anyone knows of a diaphragm replacement/kit/or knockoff carb
please let me know.
look what kind of carb is on it and see if a rebuild kit is available. Or go to an OPE shop and have then see if there is a kit.
If its a Walbro, I'm pretty sure I have a few of those diaphragm kits I could stick in an envelope and mail out. I'll have to double check my stock. I can check by Saturday.
Most of those little walbro carbs use a K10-WAT or K20-WAT kit. Usually under $10 at the local fleet farm.
please let me know.
I put in the number you provided into ebay and found this entry:
Ebay CARBURETOR-HOMELITE TRIMMER-BRUSHCUTTER-3074501
Within the auction description, the field "WYA-71" shows up, which would be a Walbro carb. If that is indeed the correct Walbro carb model, it would use the Repair Kit K20-WYA, or Gasket/Diaphragm Kit D20-WYA.
