Torco ATF
Kingsland, GA
Has anybody ever tried this stuff? I can find a few threads and some info about some Torco products, but I cannot find anything on their ATF. Here are the specs listed on their website. This will be going into a 2001 Pathfinder that calls for Nissan Matic D (of course) or Dexron 3/Mercon. Only thing is this stuff is $10.95/L. Ouch!
TORCO INTERNATIONAL CORPORATION
10652 Bloomfield Avenue, Santa Fe Springs, CA 90670
(562) 906.2120 phone (562) 906.2130 fax
www.torcousa.com web [email protected] email
PRODUCT TECH ©2003 TORCO
ATF SYNTHETIIC AUTOMATIIC TRANSMIISSIION FLUIID
>>Description
Torco ATF Synthetic is specifically engineered for severe operating conditions encountered in racing, off
highway and highway use. It is formulated using a combination of 100% synthetic Group IV/V base oil
chemistries and additive technologies designed to manage extreme loads, high operating temperatures
and high speed conditions. ATF is a multifunctional fluid for automatic and powershift transmissions
offering superior shear resistance, extreme gear protection and clean operation for extended component
durability and clutch performance. Will significantly reduce operating temperatures.
>>Features
>100% Synthetic Formula
>Superior shock load and wear protection
>Increases power efficiency
>Reduces operating temperatures
>Improves shifting and clutch performance
>>Application
Recommended for automatic and manual transmissions that specify DEXRON® III (IIE/II)or MERCON®
(M2C-185A) rated ATF Fluids. Commonly used in road racing, drag racing, off road, endurance and
circle track. Highly recommended for heavily loaded and continuous high temperature operation. Please
contact Torco for complete technical and specification information.
Meets/Exceeds: DEXRON® III (IIE/II), MERCON® (M2C-185A)
>>Typical/Test Data
Description ATF
Viscosity @ 100°C 7.51
Pour Point °C -54
Flash Point °C 228
Appearance Red
>>Directions
Follow manufacturer’s fill level requirements.
Compatible with other petroleum and synthetic lubricants.
>>Package Sizes / P/N
Description: ATF
1 Liter (1.056 US QT) A220088CE
Case 12 Liters A220088C
5 Gallon Pails A220088E
55 Gallon Drum A220080B
I've used the motor oil and MPZ additive.
The SR1 is priced well.
The ATF is very expensive compared to my favorite Mobil 1.
Give it a try and post your results.
