So a while back I bought some Valvoline Synpower Oil treatment, the stuff with boatloads of Moly.
More recently, I took advantage of a sale at Pep Boys to pick up a case of Formula Shell 5w30 oil.
So I decided to beef it up at the ratio of one ounce per quart as recommended by Molakule.
So while I was draining things, I put the silver Synpower bottle on the engine to warm it up. Once I was ready, I put a couple of quarts of oil in first, and then started pouring in some synpower. I stopped a couple times to look at the scale on the side of the bottle and see how much I had put in.
Well, I went too far. Ended up with 9 ounces in the engine. The oil capacity is 6.5 quarts.
What will be the results of this? I often have Terry do analysis, so I will for sure pull this and have him look at it when the time comes.
Vehicle is 2004 Nissan Titan, 5.6 liter DOHC V8 305HP/379lb-ft. 8023 miles at oil change, 4th change overall (intervals of 1000, 600, 2900 and 3400 give or take a few miles)
