- Joined
- Mar 15, 2026
- Messages
- 51
Anyone know the efficiency rating of Tokyo Roki oil filters? Is the media synthetic blend?
Nope. If you can obtain it from the manufacturer let us know.Anyone know the efficiency rating of Tokyo Roki oil filters? Is the media synthetic blend?
After some digging google pointed to Flatirons tuning blog, and New Provisions Racing, claiming.Nope. If you can obtain it from the manufacturer let us know.
Here’s a video from Whip City Wrencher of a used Roki filter cut open.
I’m glad you explained that to this particular member.If it's inefficient in the lab, it's also inefficient in real use. Plenty of in field study data showing the UOA particle count is higher with less efficient oil filters. A low efficiency oil filter will not result in the same level of oil cleanliness as a higher efficiency filter.
You don’t address artificially high particle concentration. High concentrations find more pores more often. Not the same as actual engine conditions in modern times. I am not going back and forth about it. In fact when I wrote my post I predicted this.If it's inefficient in the lab, it's also inefficient in real use. Plenty of in field study data showing the UOA particle count is higher with less efficient oil filters. A low efficiency oil filter will not result in the same level of oil cleanliness as a higher efficiency filter.
I said in field study data (ie, filters on engines in real life use) .. that is not "artificially high particle concentration". Like said, if a filter is testing inefficient in the lab then it's also going to be inefficient in the actual use. Believe it or not, there is a correlation between ISO 4548-12 and the real world. Why would the ISO test be around for over 25 years and be used around the world as an international standard otherwise.You don’t address artificially high particle concentration. High concentrations find more pores more often. Not the same as actual engine conditions in modern times. I am not going back and forth about it. In fact when I wrote my post I predicted this.
