moribundman
- Joined
- Jun 2, 2003
- Messages
- 23,587
Quote:
Also, Audis are typically quite front heavy
Quattros are "quite" front-heavy? Like an Accord?
Quote:
I was going to suggest a tire with an uninterrupted block of tread in the center like this one. The solid tread block in the center squirms around less and bears the brunt of load on the tire better.
If those Bridgestones don't work, you can always try the Flintstone RE-01's. They have a very stiff sidewall and the compound lasts a long time.Quote:
Recommendation: Bridgestone RE-01R
Good point. I guess I was wrong.Quote:
The ContiSportContact he's currently using already has such a solid tread block. I guess it's not helping.
Quote:
There are a couple of things not really being addressed here:
1) STIFFER SIDEWALLS - Everyone is focusing on the outer tread blocks and not the sidewall stiffness. If the sidewall is stiff enough, the tire won't roll over as much and will help with the wear on the outer tread blocks where they meet the sidewall. This is a function of the internal construction of the tire, look for tires with extra plies in the outer sidewall, or other reinforcements meant to prevent sidewall flex. Unfortunately, tires with massively stiff sidewalls usually aren't very comfortable. Recommendation: Falken Azenis RT-615, Bridgestone RE-01R, etc. They may not last as long overall, but they will probably wear less on the outside sidewall.
2) DRIVING STYLE - and I sure as ____ don't mean slow down. But, you can probably find a way to change your driving style to be even faster without sliding as much. Recommendation: Skip Barber, Bob Bondurant, etc. high performance driving school.
Quote:
Quattros are "quite" front-heavy? Like an Accord?My A4 (B5) quattro has a front-to-rear weight ratio of 55:45, not counting what I keep in the trunk.![]()
Quote:
Pete, remember this is an 11 year old car. I am not going to buy new wheels.
Quote:
There is no such thing is a tire with more outside tread so people gave you the only realistic option.
Jon
Quote:
mori, I think I've located a tire for you...
Quote:
Goodyear Eagle F1 GS-D3:
Quote:
And finally, the virtual ribs flow into the shoulder area to form long, stable shoulder blocks that grip the road during cornering and help resist the wear associated with aggressive driving
That appears to be the best candidate so far.
