Crackin' down on the members, hey Ruger?
If I had tires that were crappy and they had 50k left (on all four, if it were only the front or rear, I didn't rotate often enough), I'd still take em off and put new ones on. Remaining tread only means the tire still has life, not that they are any good, and some tires do suck.quote:
Originally posted by Ugly3:
sxg6 - just checking to see if im really as stupid as my dad/sister/mechanic/her boyfriend think.
Well let's see, you agree the tires can go another 50,000 miles, the guy who will get paid for changing them says they don't need changing, your Dad is there and leaves.
Maybe you are wrong.
Understeer was thought to be the "safer" of the two possibilities for a long time. The reasoning is that the car will hold the line just a bit longer (at a higher speed) before breaking into understeer, whereas it might experience oversteer earlier. However, understeer is more dangerous, because there is little that you can do besides stand on the brakes, turn the wheel and pray. Oversteer is remarkably easy to deal with (you're not going all the way around unless you don't know how to correct, which is really easy, and you shouldn't have a license without knowing it) by simply turning into the spin and applying some throttle if necessary.quote:
Originally posted by Matt89:
ediamiam;
Not to be some "self-proclaimed expert" on this, but from what I have read, you actually want the more worn down tires in the front.
Sounds stupid at first, but here's why: If you are going to lose traction, it's better to lose traction on the front wheels first because you can hopefully regain control when they start to grip again. If you lose traction on the rear wheels, you're going around! A lot harder to recover and more potential for damage/injury.
Basically, putting the worn tires on the front would create an 'understeer' in marginal conditions, which is safer for the avg driver than an 'oversteer'.
Last place I saw a writeup on this was the Goodyear website.
Typically, you want to have your higher-treaded tires on your drive wheels, which would mean rear wheels on a RWD and front on a FWD... in an AWD car you need to pay attention to rotation so that you are getting fairly equal tread-wear.quote:
Oversteer is when the passengers are screaming. Understeer is when the driver is screaming.
For winter, unless you live in California, swap them out.There's still 10K left on my tires and its downright scary driving on wet roads.quote:
tires, run them down or replace when worn?
