Originally Posted By: ram_man
Originally Posted By: CapriRacer
How old are the tires? Since you are in Missouri, I suspect that tires age out at about 7 or 8 years. Then they will start to separate - and your first symptom will be a gradually increasing vibration. It might be a while before you can detect a bulge, but eventually one will appear. You want to be off those tires BEFORE that happens as there is a very small window between being able to see the bulge and a catastrophic failure.
Tires are about 5 months old I believe.
Time to find a road force balancer.
