Hello all, I hope you can help me with a strange tire problem.
A friend was visiting this morning, and while preparing to leave noticed that the rear driver's side tire on her '97 Chevy half-ton was low. I confirmed with a gauge that it was down around 13 PSI.
Fired up the compressor, but was unable to get the tire to take air. Figured the valve was frozen (it's - 6 C here) and removed it. Tried to confirm that it was a valve problem by shooting some air into the tire with the valve removed, and couldn't do that either.
(The valve worked fine in letting air out before I removed it.)
So, I took a bicycle spoke and pushed it right through the valve stem into the tire. No problem. (But wondered if I'd knocked out some ice while doing so.)
Tried to put air into the tire again, both with and without the valve installed - no go.
Finally put the spare on for her. (No problem with my compressor/hose/tire-inflator thingy taking the spare pressure from c. 20 up to 35 PSI.) She'll take the flat tire to her regular shop, and I am most curious as to what the mechanic finds. This one has me stumped. Thoughts from anyone? Thanks in advance.
