Tire Weight vs Rolling Resistance
Well, when you get to 1% changes in efficiencies, there really isn’t a practical difference. A 1% change can be measured across big samples, like a fleet, but for an individual and single vehicle, that change will be lost in the noise of the data.
It won’t make any difference in your MPG.
Since you’re choosing between two AT tires, pick the one you like better on the basis of noise, traction, tread life, or even looks, because the MPG difference between your choices won’t be measurable.
And won't you take a gas mileage hit just because the tires are new?
Yes, new tires have a higher rolling resistance than worn tires, because of the increased amount of tread. I've estimated that the difference would be bout 5% on vehicle fuel usage.
Would I be right in thinking that all terrain tyres would generally fall into the grades with higher rolling resistance. I wonder how the OP determined that one tyre had a higher rolling resistance than the other. Even with no grading system yet in place, figures for the two tyres coefficient of rolling resistance in Kg per tonne could be translated in an effect on fuel economy.
Yes, for 2 reasons: Increased mass of tread rubber and the tread rubber composition. Tires designed for any sort of off-road usage will use rubber compounds that will be worse for RR.
I too wonder where the OP got the RRC values.
So allow me to explain the problem with translating RRC into actual fuel economy: Rolling resistance is distance dependent. To calculate the effect RRC has on fuel economy, it is proportional to the distance. But for steady-state driving the effect the car has tends to dominate things.
HOWEVER, there is a small speed effect - faster is worse. That's due to the additional distortion speed does to a tire.
But the effect the weight of a tire has on fuel economy is related to acceleration - frequent speed changes increases fuel consumption. In other words, weight has more effect on fuel economy in city driving, and less in country driving. But the weight of tires is relatively small compared to the weight of the vehicle, so the effect of tire weight gets overwhelmed.
So it is difficult to accurately estimate what change in RR has on actual fuel economy. Yes, better RR will result in better fuel economy, but how much? In my opinion, removing stuff from the car would have more effect.
I recently bought a set of Vredestein Pinza AT tires for my 2019 Tacoma 4x4, and I love them!
I tried a set of set of LRE Pinza's earlier this year. And they exceeded my expectations. But they were noticeably stiffer than my previous highway P rated tires (duh). And I would have lost maybe 1.5mpg if I didn't pay attention... driving slower and coasting up to stops gained most of that back. Heavy tires like to roll!
