Tire Sidewall Cracking - cause for concern?
CA
These are Continental PureContact LS tires on our 2007 Honda Accord.
The tires were manufactured in mid 2019 and have been in-service since Dec 2019. Current mileage is 32K. Up until 6 months ago, this car lived inside of a garage.
There is no cracking on the tread blocks or anywhere near the tread itself. However, these cracks have just shown up on 2 of the tires.
Do these tires warrant immediate replacement or can they remain in service?
Notice that all the cracks are kind of a curvy diagonal - nothing radial, nothing circumferential. I think that means these are fatigue cracks.
But since the sidewall rubber isn't structural and its only job is to protect the fabric underneath, I don't think this is a problem. However, they should be monitored - about once a week or once a month. If any bulges form, get rid of them. But I don't think that is going to happen.
That stinks. +1 for replace in the very near future (High speed or emergency maneuver blow-out risk)
@The Critic Curious:
- What has been your tire care routine? Car wash or dish detergent? Do you use tire-foam or equivient? (Me, I use that Maguires heavy gel stuff, It's messy, but lasts a long time and I think keeps tire rubber "Moist")
Continental’s email customer service has been very helpful for me in the past, although with a problem like this they will likely just tell you to go to an authorized Continental shop and get their opinion in person.
I rarely clean the tires, but when I do, I use Brown Royal.
Believe it or not, road grit can get into the rubber, along with brake dust, and abrade the rubber in the sidewall area. It’s a good idea to clean your tires semi regularly. I wouldn’t go overboard with it, but once a quarter would suffice. If you live in an area they use salt or de-icing agents, that can have an effect as well. Your tires “look” like they may have been run at low pressure and fatigued the sidewall. Not saying you have, but that sort of wear happens in that condition too.
I keep them at 3 psi over Honda’s spec.
6 years is a good run.
Rule of thumb when I lived in a climate with both hot summers and cold winters was to replace at 5 years regardless of mileage. Anything over that was blowout territory. I learned this after moving there and a few years later having a blowout with a 7 YO tire. I’m good for replacing tires at 5.
I had that kind of cracks on my Dunlop SP A2 back in my days working near Livermore. I think the bright sun in the summer cracked them all (all 4) of them early and they had like 3 out of 4 tires blew out on the highway without hitting a nail. I think you should start looking for replacement soon, just IMO only but I hope I am wrong.
I am not sure whether it is some formulation is more prone to UV or cracking but better the environment didn't help.
