Tire Shine that doesn't dull tires
SC
I'm not sure if this is true, but I've read other places that cheaper tire shine actually degrades and yellows tires.
What brands do not do this? Which brands are bad for tires? Any chemical ingredients to watch out for?
(I have armor all tire foam around the house, a cheaper brand)
The one I have been using now for about 2 years is Turtle Wax Jet Black. Make sure it says "Black Endura Shine Tire Coat Kit" on the front of the box. There was an earlier similar product with a very similar name but without the quality of this newer product.
Easy to use, a very nice finish on the tire and depending on how many coats you put on, it can be a dull shine or a higher gloss shine, but nothing too in your face.
It also lasts a very long time and handles rain and car washings very well. It is almost like a paint for the tires.
303 is not shiny. A very Matte like finish. I like it, a lot.
A member here who seems to know his stuff regarding such products claims it is just watered down Armor All, but I've never had armor all keep tires looking good for years on end and the glossy sheen is not something I like from armorall
My Tires be five years old this fall, and people still ask me when I got the new tires.
Without even cleaning the Tire, I spray the 303 lightly around tire, then use a sponge or foam rubber to spread it around tire evenly. The rubber seems to drink it up, and I come back with a super light second application on any dry spots after i finish the first coat on tire#4. I then wipe the black plastic trim all over the vehicle with this blackened foam rubber applicator, then with My rims being black, I wipe them with this foam rubber too.
Both repel water for upto 8 weeks, and the rims are extremely easy to clean the next time. Seems it repels brake dust.
Some report it washes off in the first rain. This has not been my experience using the application method above.
Are there better products? I don't know. I quit looking after using aerospace 303
polish the rubber
infinite shine!
Generally, you want to avoid any of the Spray/Foam/Walk-away products, as they will generally degrade the rubber and lead to premature aging of your tires.
Look for a product that is water-based, like 303 or Lucas Slick Mist. Better for your tires, and generally not ridiculously shiny - just nice and black and long-lasting.
Some report it washes off in the first rain. This has not been my experience using the application method above. . . .
I was pleased with 303, but it was not any longer-lasting in rain or my DIY car washes than Meguiar's Natural Shine. And Meguiar's is easier to find around here.
+1. Great kit although the tire cleaner could be better.
I just started to use Chemical Guys Vinyl, Rubber, Plastic Protectant on my tires and am really liking it. It's a water based gel, best applied with a foam applicator.
Good shine with no sling, and seems to be durable. Degreasers will remove it so it doesn't build up like some oil based dressings.
Meguiars Hot Shine and Insane Shine are all I use with Xcellent results, been using Meguiars tire coatings for years, to prevent tire sling I let the tires sit overnite or longer before driving
I think the general consensus is that the more a product depends upon silicone as an ingredient, the worse it is for the rubber, both visually (from buildup over time) and molecularly (also from buildup over time). I'm sure there is some truth to those claims, but I suspect once all the variables are factored in, the reality of the whole situation makes definite outcomes like those much less likely for any given person's vehicle.
If you buy and regularly use the absolute cheapest tire shine products you can find, and you rarely (or never) give the tires a good scrubbing and cleaning while doing a car wash, then you should not be surprised if the tires gradually take on a dull brown hue. And if that same approach to tire care/cleaning continues on for several years, then you should also not be surprised to one day notice cracks and brittleness are the new norm for the outside of the tires.
But let's face it, that type of apathy toward your car's tires is rare. Almost everyone will take better care of their tires, even if by accident! Which changes our formula's variables, and thus makes the outcome more nebulous.
Bottom line IMO: find a product that you like and use it after every car wash if necessary. But most important of all, clean the tires at every car wash. If you keep cleaning off any residual buil-up of the product before applying more, it will be hard for it to accumulate in the rubber and eventually cause problems.
Personally I like Stoner More Shine, SCG Beyond Black, Duragloss something_something (forgot prod's name), Griot's Garage tire spray (aerosol), and only one or two others I am blanking on at the moment. I've tried just about every OTC tire shine out there and a few non-OTC s well in an effort to find the perfect product for me. And those listed above are the one's I liked enough to use again.
Unfortunately I like the satin/matte look on the tires (on my black car) much more than the shiny, wet-look everybody else seems to love, so take any recommendations I might give on this subject as personal opinion only.
Stoner's More Shine Less Time is by a wide margin the best tire dressing I've ever used. It can be applied to be shiny or not. It lasts a long time. It's not a dust magnet like many of the others, and it won't cause the sidewalls to crack.
