Tire recommendations for the Cayman
BeerCan
$50 Site Donor
FL
10K miles and the car already needs rear tires. Has Pirelli P-Zero's now and I am not super impressed. Looking for people that have experience with summer tires for sports cars for a mostly DD What I need is a tire that is good in the rain because I am in Florida. I would also like a tire that is on the quiet side. Of course performance is a key issue as well. Usual suspects Michelin Pilot sport 4s Continental extreme contact sport Goodyear eagle F1 Bridgstone Potenza Yokahama Advan Khumo Ecsta Nitto NT555 I'm not a big Michelin fan and they are pretty expensive but I will bite the bullet if I have to I have the conti on my 951 but it's a different car with different usage pattern but for the use I like them. I have never been a big GoodYear fan but I would like to hear impressions I have Bridgestone Pole Position on the 968 but not sure if the tire is similar If the second tier tires are good I will seriously consider them. This car is hard on tires and the rears wear out twice as fast as the fronts it seems. I don't want to be dropping 700 twice a year if I don't have to. TL;DR Tires performance for some rain and DD, low noise if possible. No snow, no cold.
PA
Pilot Sport 4S, hands-down. Absolutely killer in the rain, lasts surprisingly long even with hard use, and should perform all the way down to the wear bars. Very little will compete with it on performance, and even less will compete with it as an overall package -- even among other Tier-1 tires. It makes the cheaper stuff look silly. I understand if you're worried about cost. But if your basis for value is the per-mile cost of each tire over its usable tread life -- not just how long it takes to get to the wear bars, but at what point the tire is no longer worth driving on -- the Pilot Sport 4S absolutely crushes the cheaper stuff.
Los Gatos, CA
I have the Michelin Pilot Sports on out GS350 F Sport; they're great. I will probably sing a different tune when they need replacing. Drive a performance handling car and you pay the price. I am 99% sure I will buy the Pilots again... Good luck.
BeerCan
$50 Site Donor
FL
It's a staggered setup 235/35 R20 265/35 R20 Looks like Michelin is leading the count
BeerCan
$50 Site Donor
FL
So the tires might see sebring for a DE or 2 but I'm not sure. I think I am going to use my 968 there the first couple of times for various reasons. I don't think I can get the Indy 500's in the correct sizes
Western Canada
Originally Posted by BeerCan
...10K miles and the car already needs rear tires. Has Pirelli P-Zero's now and I am not super impressed.
Did the tires wear evenly, or in the middle, or outside / inside edge ? Porsche used to have two different tire inflation specs, the max load / high speed one on the door, and a more useable comfort spec found buried in the manual. The high pressure spec sometimes leads to centre tire wear, usually seen on the wider rear tires.
USA
I hate staggered setups because you can't rotate mad Maybe you might like the Falken FK510 Simpletire and Walmart have Landsail tires for less than $100 each even in your sizes ontome
Prospect, KY
Is the car AWD or can you consider converting tires to match and be rotatable front to back? The Michelins are pretty awesome but don't have any experience with the other tires.
wi
I'd also look at Falken tires if in available size.
PA
Originally Posted by Zolton
Firestone Indy 500?
Either of those would be quite a step down, and not just in terms of performance.
Caymans are always RWD. I don't think a square tire setup would be advisable. If you had to do it, you'd do it by running the rear tire size up front as well, and that'd probably have a significant negative impact on how the car behaves and feels.
Kansas
Also a vote for Falkens. I've haven't heard a complaint about them yet. Especially since these cars eat tires.
Central Arkansastan
Sure you can. Just swap sides.
USA
You can swap sides, but that won't take care of the front-to-rear tire wear difference smirk2
Sunny Florida
I have had Pilot Sport 4S's on my sig car for quite a while now. I am always amazed at their ability to keep their grip on the pavement in all conditions. If your wallet permits do not buy anything else. They even ride nicely!
Pew
Illinois
The Pilot 4S or the Extreme Contact Sport. The 4S being the king of DD summer tires and the Extreme Contact Sport losing out a bit of dry grip vs the 4S but slightly better wet. A bunch of regional race guys here run the Extreme Contact Sport as their wet race tires.
