My trailer tire sidewall says:
Curious why "Dual" rating is less than single tire rating?
My thoughts and you can ignore as I just made it up:
On the surface, the only thing I can think of is you could for example have a max load of 3220 (1610 x 2) on 2 tires (Dual configuration) and each tire is getting ~1610 lbs (within spec) but since your total weight is 3220 lbs and if you go over a bump or if tires are not evenly on the ground (for whatever the reason), one tire could momentarily get more load than 1610 lbs on that side of the axle. that's why they left some room for safety and specified rating of 1610 which is below the 1820 lbs of a single tire spec. Not sure!
- Max Load 1820 lbs 50 PSI
- Max Load Dual 1610 lbs 50 PSI
