Originally Posted By: Ndx
Hey Guys,
What's your choice for accuracy.
Thank you
Here's what I use:
You can find it here or elsewhere on the net:
Intercomp Tire Gauge
This gauge automatically compensates for ambient temperature and barometric pressure and is accurate to
+0.1% of applied pressure. That means for a typical tire inflated to 35.00psi, the gauge reading would be accurate to within
+0.04psi. The gauge reads in 0.01psi (hundredths) increments.
Not all digital gauges are as accurate as this one. Digital gauges are not necessarily any more accurate than analog gauges. Just because a digital display may be easier to read and may give the appearance of being more accurate, that is not necessarily the case.
Just a quick note on accuracy versus precision:
Accuracy means the gauge indicates a pressure that is an accurate representation of the true pressure in the tire.
Precision means the gauge indicates the same reading, when measured repeatedly, for the pressure in the tire.
A gauge can be very precise, that is it will read the same time after time when measuring a constant pressure, but not be accurate - i.e. the indicated pressure will not be an accurate pressure, but it will be repeatable.
When evaluating the purchase of a gauge, you need to decide if precision is enough for you, or if you need an accurate gauge.
If you are shooting to maintain the exact pressure recommended by the tire/vehicle manufacturer, then you need a gauge that provides good accuracy.
If you set your own tire pressures based on the "chalk test," visual observation of wear patterns, seat of the pants, or some other method, then a gauge with decent precision would suit you just fine.
Precision can generally be had for less money than accuracy - the choice is yours.
