I recently installed an Amsoil bypass system on my 2005 Scion xA (1NZFE) and returned the oil via the oil filler cap. I already have plans to change that return to the oil pan because I fear excess oil in the PCV valve/throttle body. Another member here experienced exactly that.
But just yesterday I noticed that every time I check my oil via the dipstick one or two tiny bubbles are at the top mark. This is true even after several checks in a row. Is this a sign of the dreaded foaming I hear about? Should I be concerned that it will continue even if I route the return to the oil pan directly?
TIA.
TIA.
