Yes, sometimes just holding the induction clamp on top of the coil is enough to trigger it otherwise use a spark plug tester between the COP and plug and connect the clamp to that.I always thought a strobe might be useful. Is there a way to get an old light it to work with Coil on plug / no plug wires?
I'm keeping mine until I can afford a car that has points.Generally, no. Cars today use the crank (and often cam) position sensors to determine when to fire the injectors and the plugs. Nothing to adjust. Nothing to set.
I keep one - but I have a car with points.
Only a 3 car?I'm keeping mine until I can afford a car that has points.
And what would that be? Hmmm - Galaxie, Mustang, Fairlane, Comet, Mercury, Impala SS, Nova, Camaro, Firebird, Corvair, Charger, Barracuda, Hawk .... there are just too many choices. There is a year or many years for each one that I really like. What I need is a 3 car garage.
When my Comet was causing trouble on the road I pulled into a roadside service station and (with the owner's permission) did a quick tune up (filed and set the points, checked the timing) in a back corner in a very few minutes. The owner came over and said, "Third year?" (meaning third year auto mechanic apprentice). "Nope," I said "Year 2 in Med School." When you have an old car that's touchy you carry tools and can do a tune up pretty fast.Ever filed points on the side of the road with your gal's fingernail file or set them with a matchbook cover? Ever set base timing with a vacuum gauge? Only way to fly...
As I recall, Chrysler introduced electronic ignition in some of their '72 models, and GM for '74. Not sure about Ford.I bet the age is closer to 45+
My 1975 Volvo had them and pretty sure by 1978 no more points (seeing as I drove my 1979 from 90-98 and never did anything with points). Come to think of it, a 1976 Buick had what they called HEI. High energy ignition
