Originally Posted By: Chris142
Originally Posted By: Kestas
I have a 91 Mercury with the 302 V8 engine. I'm pretty sure this engine has the nylon-coated timing chain gears. How does one know when the timing chain needs service?
If that 302 has over 60K it's due. Those realy stretch fast and the plastic teeth jam the oil pump which spins the oil pump shaft like a Candy Cane. But it will still run.............A few minutes.
The gear tooth would have a hard time getting past the oil pump pick-up screen, though.
However, I did see this happen once to a poorly maintained Lincoln Zephyr. The engine was so sludged up that the oil pump pick-up screen got clogged with sludge. The oil pump had enough suction to suck the screen away from the intake tube. I thought at the time that perhaps this is by design to prevent total oil starvation.
Sometime later, the plastic on the cam sprocket get's old and starts to chip away. With an open oil pump pick-up, the tooth gets sucked into the pump and locks it up. Twisted the oil pump drive shaft pretty good too.
Installed a rebuilt engine along with a lecture on regular oil changes.
Even this new engine had its oil starvation problems. A few months later when it came into the shop behind a tow truck, I thought my Dad was going to go into vapor lock.
Checking the dipstick, the engine was way overfilled. I find out that the owner would put in an extra two quarts of oil when he'd go on long trips. Loss of oil pressure due to foaming. Changed the oil and filter. Luckily, the engine didn't exhibit any strange noises.
Another stern lecture soon followed.
