Do (2) drain and fills with the "J" fluid. Do a 3rd drain and fill later and use up the remaining "J" and use "S", Castrol Transmax IMV, Castrol Full Syn ATF, Valvoline Import ATF, etc. It will be fine.1. buy the 11 available quarts of J fluid to do three drain and fills myself. Cost is $81.
This looks doable by me. I can't jack up, pull the front wheel, etc. etc., on my Camry. What do others think re the siphon/replace method method?I would try to siphon or removed some trans fluid to see how bad it is. If you do decide to change the fluid, I would do it cold.
In cars that in which the siphon oil looks bad, I would siphon 1/2 quart every other day until it clears up. It is just like getting a blood transfusion at a very slow pace.
Nissan Tech News magazine.Whoever wrote that Matic-J vs S thing should have someone else review it. They contradict their 1st sentence with the rest of the write-up. And what is the "extraordinary steps" of bolting the dipstick in place supposed to mean ? Yes, there's a bolt, but it simply "secures" the dipstick in (not sure why it's necessary but it's not an impediment). All G35s have a dipstick too.
Was that really written up by Nissan ? Just now looked at it directly.... It seems like a dealer wrote it up or someone because they write in 3rd-person referring to Nissan at times.
Not necessary. I don't believe the old wive's tale about "oh no, don't touch that fluid !!" when people pick magic, random mileage numbers. Do a single drain and fill at a minimum then repeat in 10k, 15k, 25k miles.What do others think re the siphon/replace method method?
My MO - all trans fluid is replaced at 30K unless I know that car lives an “easy” life. By easy, I mean no stop & go, no short-tripping, no hills and if the car doesn’t get an opportunity to stretch its legs on a good length of freeway.Not necessary. I don't believe the old wive's tale about "oh no, don't touch that fluid !!" when people pick magic, random mileage numbers. Do a single drain and fill at a minimum then repeat in 10k, 15k, 25k miles.
Thank you for the response. The drain and fill on my Camry requires pulling the front wheel so I was asking if siphoning and replacing 1/2 quart at a time from the at reservoir would be helpful for those of us that don't want a flush but can't easily drain and fill.Not necessary. I don't believe the old wive's tale about "oh no, don't touch that fluid !!" when people pick magic, random mileage numbers. Do a single drain and fill at a minimum then repeat in 10k, 15k, 25k miles.
Thanks so much.What is an "at reservoir" ? I presume you mean suck it out through the dipstick tube ? If so, that's a semi-common method some people use.
I thought it was Hyundai and Subaru but the transmissions were the same. At best, they could have slightly different programming logic that each manufacturer dictates. I know in Subaru models, they spec'd "ATF-HP" fluid. Are we to believe that Subaru ATF-HP and Nissan Matic-J are secretly the same or do these transmissions simply not care or require anything special after all.Also of note - Nissan sold the Jatco RE5R05A transmission to both Mitsubishi and Subaru in the past and they used their own fluids in them. Its quite possible they were different versions of the transmission - I could never find much data on it.
I could never figure out what the ATF-HP angle was so I can't comment on that. However I do know The transmission was originally built with Matic J as the spec, then it changed to Matic S - which is my understanding a very different viscosity at the least. Also on the Nissan specific boards there are a ton of people running Maxlife which is the cheapest swiss army knife fluid ever which meets a ton of specs. So I won't say those are the best for it, because working with different fluids and benefiting is very different, but its obviously pretty tolerant, and there are a ton of them around with 300K+ miles.I know in Subaru models, they spec'd "ATF-HP" fluid. Are we to believe that Subaru ATF-HP and Nissan Matic-J are secretly the same or do these transmissions simply not care or require anything special after all.
Lots of acronyms on "Bob". I suppose DMF refers to a dual mass flywheel (a more or less conventional manual).Nah, the cost of clutch jobs on cars with DMF's makes manuals a false economy.
Yes, DMF is dual mass flywheel.Lots of acronyms on "Bob". I suppose DMF refers to a dual mass flywheel (a more or less conventional manual).
You don't have to do a lot of clutch jobs if you know how to drive a manual. In almost 60 years of driving I've only replaced one clutch and that was because the linkage broke on my '86 Volvo 740 Turbo - at about 180,000 Km. We replaced the clutch and pressure plate "while we were there". That clutch still had quite a bit of life left in it.
And I taught our daughter to drive on manual cars as well. My wife and daughter both prefer manuals.
I had a clutch in an '88 Escort last 260K and the one that replaced it had about 208K and was still working great when I retired the car. Lots of those miles were city driving in and around Charlotte, NC. The only clutch that wore out prematurely on the Escort was the original that wore out at about 50K miles and was while my brother owned it. I think what happened with it was one of my nieces that didn't know how to drive a manual drove it and burned the clutch out of it. A clutch will last a long time if the person using it knows what they're doing. Years ago a friend was changing some bearings in an '84 Mazda B2000 transmission for me and I told him to go ahead and change the clutch, pressure plate and throw out bearing which he did. The truck had 80K miles at the time and he told me after changing it the old clutch still looked like new.I’ve known people who went up to 180-200K on the OE clutch - but the car was on its last legs.
