- Joined
- Sep 17, 2025
- Messages
- 357
I recently came across a few youtube vids with some Mazda3 owners grounding their throttle bodies to the negative battery post ( or ground it to chassis) with a thick gauge cable/lugs. Did a bit more online research and besides the many very pleased Mazda3 owners who did this wire upgrade,i found a few more bits of online chatter coming from Tacoma, BMW, Dodge Charger , etc, owners who found it gave better idle, better mpgs, better throttle response, better-crisper Automatic shifting response.
At worst, either no change or just better idle/smoother shifts. The cable is fairly cheap to buy. Here in Canada, a four Gauge 25 inch cable with lugs on each end is only $11.49 plus tax. It would take only a minute or so to install . I suppose if it does absolutely nothing, I can remove it and ground other areas of more importance.
Any thoughts/advice on this TB grounding?
