Originally Posted By: rationull
Originally Posted By: Winston
Pumping method will lead to failed master cylinder often times.
How's that? The two-person pumping method is what's recommended by the Honda service manual and seems to be the old, tried-and-true method.
I think, he’s talking about cases where the fluid was never changed and parts in the master get rusty from moisture. Since in every day operation the pedal doesn’t go all the way to the floor, parts that contact are rust free, but during the two men method flush, the pedal goes all the way to the floor and the corroded parts of in the master cylinder, that never made contact before, are now being forced against each other. This can damage seals, and scratch the mating surfaces which will lead to internal leakage.
But this is only a concern in old and neglected cars, if you do regular fluid changes there is nothing to worry about.
