Thoughts on Havoline DS
Abingdon VA
Just wondering what you all thought of Havoline DS I saw its pretty cheap at walmart under 3 bucks a qrt. I use to use it a few years ago.
would it work good with auto rx also.
I would be using the 5w30 - 10w30
A lot of people report good results with it. I bought a bunch of 10w30 at Advance Auto... They clearanced the old stuff online. I bought 12 gallons at .99 per. When I showed up for pickup they loaded me up with my order. I didn't know the difference at the time. But they filled my order with the newer DS. Right after the first change I noticed a lash adjuster tick. I assumed a funny filter. I've since changed it several times using the same oil different filter. o'rielly's, puroilater, super tech, and a cheap proline. That tick was always the same. I have a huge stash... over 220 qrts at last count. I selected another brand during the last change just a day or so ago. I thought I should start pulling odd older stock and had 3 qts of older synpower and finished it off with an oddball qt of gtx all of it was 5w30 and a super tech filter bought at the same time the others were. The tick went away.
It was probably doing no harm, but was annoying. I'll use the DS in mom's car or friends, mine doesn't seem to like it.
DS is just as good as any other conventional oil, I still see some Walmarts with the 5 quart jug for $7
its a good oil, used it for 5300 miles once, usually use it in my little nissan pickup, i buy in bulk when on sale. never had a problem with it and my big block seemed to like it
One of my personal favorites. I bought a case of it a few years back when it was only .69/quart at CSK (Anyone else remember those days? I miss them!) and I wouldn't hesitate to use it again.
