- Joined
- Jun 2, 2003
- Messages
- 23,591
I read the fuel injection pressure on a PD diesel engine was up to 2,400 bar. That's almost a whopping 35,000 psi! Higher pressure means better atomization of fuel and thus better efficiency.
quote:Ah, brings back memories of military immunizations, except they used vaccine, not diesel fuel!
Originally posted by k1xv: They say if you crack open a connection while the thing is pressurized and it sprays you, the oil goes right through your skin.
quote:The jet I flew back in my aviation days (the EA-6) has a 3000 psi hydraulic system. We were taught to treat it with the utmost respect. Any time you approached a running jet (or one hooked up to a hyd cart) or opened a panel, you were to look for a pink mist or cloud (milspec hyd fluid is cherry colored). If you saw this, you just went the other way, quickly. The 3k pressure is enough to cut skin like a blade, when in a tight stream or to auto-inject, like a bulk immunization device. I can only imagine (not a pretty picture) what 35k psi (10x plus) is going to do the few unfortunate, untrained fools who mess around improvidently under the hoods of their diesels. . .
Originally posted by k1xv: They say if you crack open a connection while the thing is pressurized and it sprays you, the oil goes right through your skin. I believe my GMC Duramax operates somewhere way up there in pressure.
