Originally Posted by turnbowm
Originally Posted by 69Torino
It wasn't metal shavings. If it were, the bearings would be trashed instantly. They wouldn't make it 30-70,000 miles before turning into a rattle box. The revised engines had a different balance shaft/oil pump assembly, different oil pan, and different oil dipstick. The ones that passed "the test" got a new dipstick with allowance for more oil in the sump. And they made (MADE) us, under penalty of not paying the claim, put the oil they supplied in after the recall. Which happens to have been 5w-30 Mobil conventional. It's an oil related problem, for sure. Not swarf in the galleries.
Can you explain what you mean by "oil related problem"?
For my 2015 Ka 2.4L GDI, viscosities of 5W20, 5W30 and 10W30 are recommended/required in the OM, which should provide adequate lubrication for all situations. I assume the engine changes you refer to were made in MY 2015.
Your second question is much easier to answer. Yes the 2015 model year was rolled out with the revised bottom end on 2.4 and 2.0T engines. No worries there, I even have a 2015 Optima 2.4 in my driveway.
The first question, I wish I knew the actual reason for the failures, to exactness, but I don't. I only have context clues from having dozens of them apart on engine stands, even before the recall. I have a time lapse video of myself building a Kia 2.4 in 6 hours, condensed to 30 seconds. It's an awesome video. Kia maintained a stiff upper lip on the issue.
It was almost always rod bearing number 2, and sometimes number 4. When it was number 4 that was locked up I had to blast through the aluminum bed plate with an air hammer to access the rod bolts to loosen them and rotate the engine to remove the torque converter bolts. Major pain. I digress... knowing what I've seen and been through, I believe a good Synthetic 5w-30 is the elixir on these engines. Hope this helps a little.
