“The Truth About Electric Towing” - Video
USA
A bunch of good EV towing tests from the “Aging Wheels” YouTube channel.
Some interesting things. He made this flat-front trailer with terrible aero. That trailer with and without a Polestar on it was almost the exact same efficiency on the freeway. Weight almost doesn’t matter when it comes to freeway towing - it’s about aerodynamics.
They freeway towed the same trailer with a Silverado EV and Rivian. The Silverado EV ended up being slightly more efficient.
It doesn't matter if you end up at the same height.
I run (sometimes) an electric bus in city traffic, with very little flat roads. Stops are a quarter mile apart and I can do 1mile/kWh, weather permitting. Heating or cooling the bus can cost as much as driving it.
If the vehicle is equally efficient at all points on the power band, then in theory, sure. I know for ICE towing this is very much not the case, where even for our turbodiesel that has the torque to maintain a gear at steady speed, BSFC takes a dump at each end of the power band.
Yes bsfc is best around max torque for ice vehicles. But for gas engines we get throttle losses aswell, which reduce with larger throttle openings, so I'd say best bsfc slightly above max torque rpm, and for diesel at or slightly below.
Maybe someone will do a real test..say from las Vegas to Los Angeles on the 15 up mountain pass?
There’s this one. They basically all got the same efficiency, but the Silverado EV w/Max Range pack charged once or twice vs. 4 or 5 times on all the other trucks (I don’t remember the exact details) .
Have yet to see any truth in towing with an EV when gas is cheaper than milk.
It's because there isn't much savings when using public chargers. EV towing has very specific use cases. Towing frequently around town, like a trade, where you recharge to full at home or at a business. Or for personal use where you tow a boat or trailer to a local lake or campground. For anyone towing a trailer long distance frequently, it's not really suitable because there aren't enough pull through chargers and public charging costs will chew through any savings from going electric. Here's an EV calculator you can play with.
https://chooseev.com/savings-calculator/
My numbers look like this:
Ford Expedition EL - 9 mpg towing, $3.00 premium (Costco FTW)
Silverado EV (hypothetical ) 1 mile / kWh towing, .40 cents kWh public charging
The public kWh rate is like 3x - 5x the residential rate. So for local driving, the savings are substantial over ICE. For most people, towing makes a comparatively small portion of their overall mileage. more than enough to offset any additional costs from occasional public charger use.
